Restoring Tiny Titan replica >> just cut in two?
JeroenWe
Post by JeroenWe »
Hi all!
Recently I bought a project for my son and me. It's a Tiny Titan replica (12,3 feet long) made in Fiberglass.
In the front are some dents that I want to straighten out with (I think) wooden panels. I also need to reinforce the hull.
But I can't get there because it's all closed.
My first opinion is to just cut it in two so I can get inside the hull, reinforce everything, and put it together again. My first question is, where to cut? I can't see how it's molded together originally. I thought maybe like a butter-cup construction? (I hope you know what I mean)
Second question, how can I 'glue' both sides together again and be 100% sure the boat will be stable and safe.
Thank you for thinking with me!
Best regards from the Netherlands!
Jeroen
Re: Restoring Tiny Titan replica >> just cut in two?
Typically fiberglass boats are joined top and bottom along the edge. I would suggest to sand the paint off in a few places to see if you can find a seam.
As far as putting it back together, a good quality epoxy (West Systems, System3, MAS, etc...) will be your best bet. You may need/want to add a strip of fiberglass tape along the joint. Search through this forum to see how builders are glassing their hulls, or pick up a book on fiberglassing to figure out the process.
You might just look at building a Tiny Titan from scratch. It will probably be lighter and would also be a good project for you and your son.
JeroenWe
Post by JeroenWe »
Thank you for your quick response Jim!
I might consider to build a Tiny Titan from scratch :)
Return to “Fiberglass”
