Silicone bronze vs. composite fasteners
Tips for new builders from old builders about things they might have done differently if they had it to do over again.
Moderators: Roberta, Bill Edmundson
Williamdor
Post by Williamdor »
I'm looking ahead to building a boat from Glen-L plans, but know that I'll be weary hammering (and subsequent bending of nails and then their removal) of the silicon bronze ring shank nails. Gayle confirmed what I had concluded, collated or coiled silicon bronze ring shank nails do not currently exist. She recommended that some builders used Raptor composite brads and finish nails with a Raptor nail gun(s) instead of conventional silicon bronze. She knew of no problems with the composite alternative, but said that testing had never been done by Glen-L to confirm that these Raptor finish nails and brads were a suitable replacement for silicon bronze. I saw this link https://www.boatdesigns.com/Raptorreg-F ... ducts/926/, but wanted any subsequent opinions on the subject.
Regards,
Williamdor (a newbie)
Re: Silicone bronze vs. composite fasteners
I used the ring shank nails to assemble my frames per G-Len plans. When it came to attaching the plywood skins, I switched to SB screws since i didn't like the idea of hammering on my frame.
I think the Raptor fasteners are mostly used in cold molding construction to hold the layers of plywood in place while the epoxy sets up.
Williamdor
JimmY,
Thanks for the feedback and for explaining where you thought Raptor composite nails had their place. I do like the idea of using SB screws instead of ring shank nails as you described.
Regards,
Return to “"I Wish I Had..."”
