Marine plywood prices
The availability and price of marine grade plywood is ridiculous right now. $156 for 3/4” Doug Fur is cheapest I can find. Okoume is unavailable. Any help out there?
Re: Marine plywood prices
I've got 3/4 fir for $129 at my store. Not really helpful though.
This is also not helpful to you immediately, but they do appear to at least have some in stock. It's the place where I got the ply for the Geronimo. Where do you normally get yours?
https://www.hardwoodstore.com/hardwood-plywood
Try World Panel. They have all sizes of Okoume. Not cheap.
couple days ago I saw marine fir at local box store. less than $156 you mention
Oak..........the juice ain't worth the squeeze
I normally use Homestead in Ohio, but they are out of some sizes and I need to order all the material in one order because shipping is $250.hoodman wrote: ↑Fri Jan 28, 2022 8:27 pm This is also not helpful to you immediately, but they do appear to at least have some in stock. It's the place where I got the ply for the Geronimo. Where do you normally get yours?
MB
Gosh, where is the price of epoxy gonna be?
I remember I had approx equal costs in the wood an epoxy
Back in November 2013 and January 2014 I ordered the following Okoume BS1088 Lloyds certified plywood from World Panel. Each order cost $200,00 on average to ship from NC to WI. One order was 30 sheets for $220.00. The other was Four sheets for $190.00. All sheets were 2500mm x 1220mm. 4x8.
3mm (1/8) : $42.00 then, $68.64 now
6mm (1/4): $61.00 then, $121.68 now
9mm (3/8): $72.00 then, $164.67 now
18mm (3/4): $130.00 then, $232.54 now
Glad I'm not looking to order any plywood now. Covid? Supply Chain? Will it come down? Or go Higher??
Might be Demand for ply during storms.I was adding onto house during hurricane Andrew and watched chipboard go from 7.00 a sheet to 30.00 in no time flat.Couldn't get the good stuff -just the stuff with black paint on it.
One thing about World Panel is that they crate the order with some very useful sheeting like cheaper plywood or MFD boards that I used to protect my work table top or use as shelves. They did a good job protecting my order.
Prices in my area. http://theworkbench.com/plywood.php#marineply
http://theworkbench.com/exotics.php
This is where I got the lumber for my little skiff. About a 2 hr drive. Looking at the prices it seems they are actually pretty much what I remember when buying the 1/4" and 3/8" BS1088 for that project in 2017
Several years ago I started lucky pierre dory and Was taken aback by the prices of marine plywood. I read that Chris-craft used sign board in their boats. I have a friend who owns a sign shop and had him order all the plywood I would need. At the time it was cheaper than marine plywood and works just fine for me. What convinced me besides the obvious
(Chris-craft's use) was the signs are outside in the elements all of the time and remain in good repair. wayne
