Reggie wrote: ↑Fri Jan 28, 2022 1:53 pm
Thanks for the replies … so my two stitch and glue boats … an 18 foot dory and a center console are from a different designer … so I thought it might be inappropriate to post here.
Having said that I was given plans for the Glen L console skiff and I love the lines … so that may be in my future.
Coming back to the Riva … using the boat is definitely the intention… not restoration accolades by a bunch of purists at some annual and obscure gathering…
My question was more about how best to do the modern methods?
If one was using epoxy, fillets and glass sheathing at the waterline is there still a need for fasteners … for example.
Should one sheath the outside and inside?
Epoxy coat only?
How will this interact with the parts of the boat that are in a more “natural way” still?
That was sort of what I wanted to discuss…
In the modern methods, that layer of waxy gunk between would now be a epoxy resin glue bonding the layers.
On the outside I would definitely epoxy 1 thin layer of glass cloth. Glass cloth if purchased correctly, applied correctly, will go clear at under 6oz/yard.
On my canoe build, I used a thinner 4oz cloth S-glass and I really like it.
Just cloth the outside. Inside is encapsulate only.
Since a good epoxy bond is stronger than the wood itself, it doesn't really matter if you leave fastners in nor take them out.
I use a lot of wire brads (brad nail gun) to hold parts together while the epoxy cures, then the brads are nearly invisible. Stainless brads can be left in, and the plastic RAPTOR brads are left in.
