Carioca 17' Germany
Juergen
Carioca 17' Germany
Post by Juergen »
Hallo boat builder !
I intend to build a "Carioca" :D
Under the category "New Members" , i have already introduced myself.
I hope to be able to ask my questions here
and I think there will be a lot of questions !!! :?
At the moment I'm still brooding over the plans and part lists.
On the title "Carioca 17' Germany" , you can see that i calculate with cm and mm.
That doesn't make any easier ! :(
Best regards
Juergen
Excuse my english ! My friend is google-translator ! :wink:
Re: Carioca 17' Germany
Good job. Hopefully your thread will attract builders and any help you may need.
Juergen
Post by Juergen »
Let's try, Roberta ! :wink:
Juergen :D
sshamilt@gmail.com
Post by sshamilt@gmail.com »
You came to a good place. The people on the forum have been great for me.
Juergen
Post by Juergen »
Hallo Steve !
I already feel accepted, nice people here ! :D
Juergen :D
Juergen
Post by Juergen »
Hallo friends ! :D
Here is my first question.
Holes for water drainage are provided in the Frames along the keel.
Left and right.
And than ?
Motor Well has Drain Holes, see image.
How does the water come out of the bilge ? :?
I think that also appies to other boats.
Holes to the left and right of the keel in the Transom ? :?
My idea, 2 bilge pumps, left and right from the keel. Outlet above the waterline. ( no Titanic) :shock:
Other solutions ?
Juergen :D
Post by DrBryanJ »
Juergen:
I have done just as you describe. Two bilge pumps and drains on either side of the transom knee (don't forget your drain plugs). I know some have not installed drains, and others don't have bilge pumps. Having both just makes me feel better.
sshamilt@gmail.com
I think having the transom drains is a must if the boat will be stored outside and on a trailer. If it will be in the water all the time then the drains would not be as needed since you could never pull the plug.
Juergen
Post by Juergen »
Hallo friends !
Can't build so fast as the answers come here ! :shock:
The boat is always taken out of the water.
For this reason also the size of the boat.
This can still pull my car ! :wink:
Juergen :D
Juergen
Post by Juergen »
As for the constuction
I have thesame problem that all builder seems to have had. :roll:
Wood procurement !
Have to see what i can get better to buy.
Mahogany or Oak !
Will call my timber dealer next week, what he can get more easily.
Juergen :D
Mahogany is better. Don't use red oak.
Juergen
Post by Juergen »
No, then thought of white oak !
Juergen :D
White oak is fine. Red oak rots too easily.
Red Oak absorbs water like sponge. Then it swells. When it swells the encapsulation breaks off. White oak doesn't do that.
Juergen
Post by Juergen »
News ! :D
I received the first plywood for the corner joints of the frames.
Birch 6,5 mm ( 5 layers ) , something more like 1/4". Norm BFU100 ( water resistant )
The wood procurement is much difficult than expected !
Mahogany is the hard one to come here ! :roll:
But how did Glen write ? "Use what you can get" !
We grow a lot of white oak ! ( in front of the door ! ) :)
I ordered the first samples.
26mm thick, a little more like 1"
Mahogany is a must for a "runabout" like "Monte Carlo, Riviera, Torpedo" and so on !
But the "Carioca" doesn't necessarily need that for its appearance. :wink:
Look : GaryS "Mai Tai"
Juergen :D
