The keel has been fitted, so I guess we officially have a boat.
I spent a good part of the day trying to get everything lined up and straight. This was primarily my fault and largely due to trying to get everything to fit the building form. But the OSB form is just too flexible to rigidly hold everything in alignment by itself. I eventually reverted to my aircraft building background and reminded myself that
we are building a boat, not a building form. The form can be as crooked as a banana as long as all the boat pieces are aligned. So I moved things around on the form until the penciled line down the middle of the keel aligned with the string I pulled from stem to transom. I also clamped the chine logs into place to make sure the transom was square with the longitudinal axis of the boat. Then, the keel was dry-fitted to the frames. Several measurements indicated all is straight and square, so final fitting and attachment of the keel and chine logs can proceed.
Here are the 2 x 4's I added to the form to provide an easy way to clamp the frames in place.
Note: While the highly engineered Zip Kit has been a pleasure to work with there is one aspect of building with precut pieces that we need to remember. When I initially fitted the chine logs and keel....they were 3/8" too short! I'm sure what happened is there was a stack-up of tolerances in my assembly of the stem/chine braces which did not precisely match the CAD design. The remedy was simple, I just trimmed 3/8" off the aft end of the building form to move the transom forward. We're good to go, now.
