Building a La Paz 24
Re: Building a La Paz 24
Looks very sharp... crisp, clean lines and nice curves.
- Bill Edmundson
- Contact:
I like it!
Thanks fellas.
For some reason I'm not getting notifications when someone posts.
Very NICE !!
What kind of paint process did you use?
Oak..........the juice ain't worth the squeeze
Thank you, Ken.
Following the fairing with US composites fairing compound/epoxy, I followed with Alexseal products. First with Superbuild 302 high build primer, then followed with their finish primer (after sanding). Sanded that, then 2-3 coats of Alexseal 501 Topcoat (sanding between coats w 400 grit); Thunderstorm Gray (dark gray), Pegasus Gray, and Matterhorn White. All rolled I should add.
Very nice.
Awesome!!!
Very nice!
Thank you all.
I guess it's time to update my build.
March, 2021 I ordered a trailer; "8-10 weeks" I was told. Knowing it would be a while I went back to daily employment and just did a little work on my console. Well, 8 weeks went by, then 10 ..... 12.... . I went to wash my boat down one day and had a sickening feeling as I saw 8-10 hairline cracks in my lift strakes. Some cracks were 3-4", one was about 18". Figuring it was more than just the paint, I sanded down to the wood and sure enough the Sapele was cracked (first pic shows a short one).
So I stripped all the lift strakes down to the wood, the surrounding hull as well for about 4" on either side. Man, this was difficult, "ruining" all my work. I filled the cracks with epoxy then glassed over the strakes their entire length with 2 layers of 8.7 oz biaxial.
Naturally, I then had to refair and repaint. From the time I ordered the trailer until the time I finished painting, 7 months. And I still didn't have a trailer. In retrospect, I wish I would have just build a cradle and rolled it over from the get-go. Here it is, version 2.0. First primed, then painted.
