Texas Barrelback 20
Re: Texas Barrelback 20
I never had a problem with using garden hose on my 5.7 GM engine. I actually keep the flow down a lot so that it just trickles out the exhaust a bit. Just close the seacock and turn on the flow. I generally keep the engine at idle or slightly fast idle with an occasional quick rev up.
Here is a picture of my setup of the Flushing "T" in the intake hose.
I'm with Roberta and use the garden hose only. A water saver faucet will not meet the WOT demand but it should be OK at a low throttle. My engine reads about 170* after warmup on the lake. I would shut it down if I started creeping above that in the driveway.
I don't want to wait for the boat to fill with water to the hose inlet if I ever need the crash pump function, so I added a 3' section of hose to the hose connection with the open end lying in the bilge.
In the home stretch on a Tahoe 23 & just starting Rosita
I have a hose with a suction screen that came with my flushing "T" for emergency bilge pumping. I'd have to have Rich crawl out back there to hook it up, though. That would be fun. :lol: I suppose I could hook it up, then he would just need to re-valve things.
All the above 3 or 4 posts are all trying to get wayyyy to technical.
It doesn't damn matter if you got a 5.7l GM engine. doesn't matter if you got a hose in a 5 gal bucket.
doesn't matter if you got the 'Fake-a-Lake' toilet plunger on the boat bottom.
Any of those will work, and work OK.
After all, you ain't gonna make the engine heat of WOT when you on the trailer, ain't gonna happen.
all you doing at best is looking for leaks. that's fine and prudent.
Who among us has plumbed their engine with clear vinyl hose and observed all the air actually sucked into the intake on plane ??
Anybody with a free beer at the G15?
I agree with Ken. My engine will not even heat up at idle speed. I run the water to save the raw water impeller.
Bill is correct, it is more about wetting the impeller, than it is about heat transfer.
psychobilly
Post by psychobilly »
Well Steve, you test run that baby yet?
steves
Post by steves »
Hey PB,
not quite yet, holidays and family activities as well as how much fun wiring is does not lend itself to fast progress!
I'll be on vacation for a week then get serious about it. I may need your electrical guru again!
Hope you are well.
Looks like 2022 is shaping up to be another banner year in boat launches. I know what you mean about fast progress, my punch list grows faster than I can complete items. I have to tackle electrical real soon as well.
steves
Post by steves »
Carl,
I have a mental punchlist, I'm afraid if I put it all on paper it would be too discouraging!
Good luck!
psychobilly
steves wrote: Fri Nov 26, 2021 6:40 pm Hey PB,
Hope you are well.
I hear ya, I’m still in a food coma!
Lemme know if you need Chris’ help. He’s 15 min down the road from ya.
DavO
Post by DavO »
Fellow Texan building a 20' barrelback here. I am about to wrap up the varnishing and will be turning to the interior after the holidays. I am interested in having front bucket seats, which I believe you are considering as well. Is that correct? If so, can you share some details and pictures? Also, I am in McKinney, which is north of Dallas. Where are you located?
David O
steves
Post by steves »
I made my own transom bands and working up the courage to make the cutwater!
steves
Post by steves »
David O,
yes, going with bucket seats in the front and a bench seat in the back. I found dimensions and sketch here on the forum somewhere! I'll look again and see if I can come up with a picture.
If you go back to June 28, 2019 on this thread, you can see a picture of my bucket
I'm down in Friendswood, between Houston and Galveston.
steves
Another mileston
Post by steves »
What a day, I was just testing to see if my ignition and start wiring was good and damn, it did and she started!
I didn't have fuel in the tank yet but there must have been some left over from the factory test.
Wooohooo!
