Possible new build
Possible new build
Was researching a possible fun boat when I came across a"Zipper". Can't have much weight capacity since only 4ft. wide x 8 ft.long,18 hp motor and 6 gal tank and can tow skiiers.Imagine can be a little tricky with the foot steering at advertised speed of 36 mph.
With my 260 lbs might be named"Titanic2" or Deep 6 Suzie Q
Re: Possible new build
Looks exciting.
Says it take 17 hours to build.can also be used for musky fishing and duck hunting.kinda looks like it has a built-in wheel chair and I might need one if I build it.
Or build one of these.
Plus visability in this lake is only a foot or 2.
wouldn't have to worry about sinking.Not sure if the flannel shirt will keep me warm.
Tow that one behind the first one. Looks like a good musky trolling bait. Tom
Scooter looks more comfortable and user-friendly.
OK, but can you still use a shop stool with the flames as a seat? https://www.harborfreight.com/flame-des ... 91200.html
Sure! Just modify the seat area.
Put two on.
Put two on.
That little zipper-guess if using foot steering,the 2 hands can be used for throttle and camera.Is that mounted on long selfie stick?
