Baron
Ray built his True Grit with a composting head and was a mentor when I was building my True Grit. His is 27' while mine is 30' so we both have a lot more room to work with than what you are looking at building. Ray has his head in a smaller space with a shower located in a separate space. No matter what system you decide to install, sitting down for everyone is probably a better thing in case a wave comes and rocks the boat.
Curt
Head Placement
- Bill Edmundson
- Contact:
Re: Head Placement
Baron
Those are the float switches for the pumps. I can also switch them from the helm. The large hose is the bilge blower. The fuel tanks and batteries are also down there. Also room down there for my Yeti Cooler. Most of the time the a cooler sits on the platform over the head.
Re: Head Placement
You folks are so fortunate realizing you had this love of building early enough in life to get some builds under your belts. I've been dancing around the perimeter and never really committed to a substantial boat.....just little things.
Anyway I drew a close to scale version of what I had in mind and now I know more accurately why Designers rarely put a head on a small boat. The thought was to put it immediately behind the helm so the helmsman has very little obstructed view. I forgot that the Little Hunks floor is only 4.5' wide. By the time I was done playing I only had 4' od deck left. Furthermore that much cabin on a little bitty Dory is not very attractive.
If I can't figure out a better solution then I have to move to a longer and wider model. I really wanted a smaller 19-21' boat but I may have mis-judged this.
here is the rough draft:
- Bill Edmundson
- Contact:
Re: Head Placement
Baron
I had to turn the head at an angle to have a little leg room.
Re: Head Placement
I believe it but it does look like nice and neat install. I can no longer live without these devices.
Re: Head Placement
I had a homemade composting toilet installed in "Chug" made from square kittykat litter bucket.But read later that Canada requires a holding tank(not being able to dump without pumpout)Cat litter would be purrfect as it works for stinkykat stuff.Just buy bucket of cat litter,dump into ziplock bags,use bucket and cover with cat litter,bucket full discard or dump out and get new bucket of cat litter.I've tried whizzing in coffee cans with wood pellets when I'm working on boat and noticed no odor after a few days.Just don't fill with pellets as they expand quite a bit
Re: Head Placement
Chugalug, you've been out in the woods tooooo long. Its time to come home now. Leave your cat litter out there though, lol, lol.
I like the theory of Compost toilet and suspected that Canada wouldn't like them much. My wife on the other hand would not do well with Cat Litter and coffee cans......I barely believe I could get her to consider the slick looking Nature's Head product but I'd try. I am now thinking to go the product below with the built in 9 gallon tank. It has a small footprint and would last several days longer than my Porta-Potti. Some time back one of the famous 80's authors (probably Parker or Bolger but not sure) wrote that they felt a built in tanks, heavily glassed right into the build, would work well as composting toilets and should be fitted with a 3" vent. I wish I could find that article for I may be mixing it up a bit.
- Attachments
- IMG_1072[1].jpg (19 KiB) Viewed 4304 times
Re: Head Placement
Re: Head Placement
Chugalug,
Have you used this toilet yet?
Does it have a clean-out vent to the gunnels?
Nice Boat. I've often admired aspects of the Bo-Jest Design.
Re: Head Placement
I haven't used yet.There is a 1-1/2 inch fitting that hooks up to hose that needs to be glued in, but after reading a sailboat site that used all pvc pipe,I'm going with that.My plumbing fitting threads may not match up but this spring,I'm going to build a pumpout tank hooked up to pump(not sure if I'll use a manual pump or macerator pump.the only elbow on toilet tank is a 45 glued to tank and pipe is run at a 45 degree out througth the pilothouse side.We got snow out now and -35 wind chill so don't think I'll do much boating for awhile
