Boat ballast
Boat ballast
Just thinking about putting in form of ballast in "Chug-A-Lug" to prevent roll over in heavy waves.I've been researching water tanks built from ply and epoxy in"Duckworks".Water tanks or containers of potable water? Also might put 2 deep-cycle batteries as house set-up there .That would add 150 lbs or so under the sole.Can't seem to find any articles about ballast on Glen-L site.Thoughts anyone?
Re: Boat ballast
Re: Boat ballast
going with the weather is the most dangerous. a following sea can push on the transom and basically shove the bow into the wave in front of you.
about that time, the boat slows because the bow just hit a big one, but, the wave coming over the transom just keeps coming on and pushing. No joy.
The following sea is a smoother ride, yes, but a broach can sneak up on you. you definitely busier at the helm on following weather. high freeboard is a plus in this stuff. next time you out in a big seas, go with the weather and just watch how high up waves climb the transom !!! But be ready for it !
Re: Boat ballast
Yeah! When the waves are going faster than you,tends to broach a little -alot of steering correcting.I was just out to see if I would have problems.It took me 2 hours of chugging to get to that spot.There is a few islands with cabins nearby.I never venture out to the Big Traverse as there are no islands to hide behind down there being only 30 ft deep,storms can form really fast.The 30 ft passenger boats had to tend to 9 and 10 ft side winds last summer.Some of our(Moms resort) guests got beat-up a little.
Re: Boat ballast
I got on top of one of the bigger waves on following sea, I held on right on top, looked at my GPS and the wave and me both was moving 15mph.
Pushed it on over the top and surfed like a surfboard.
For some reason the shallower waters tend to get rougher than the deep, somehow the wind doesn't whip up the deep water like the shallows.
Re: Boat ballast
I've done that years ago, when I had my 24ft Fibreform boat.Chug is my slow Bo-jest boat.She just can't keep up to the waves so trials sometimes were pretty rough.Canada waters are closed this last year to recreational non-residents so weren't able to venture up there so limited to Minnesota side only.Hope this year will be better.
