Gentry flotation and HP calculations - Any available?
Trackhappy
Post by Trackhappy »
In Australia an owner-built boat now has to have an "Australian Builders Plate" fitted prior to sale if it was built after 2006. I don't have any plans to sell Genry yet, but this seems to be the right time to get the information, and plan inbuilt buoyancy etc. if required. Trying to fit it in later might be difficult.
This standard explains the requirements:
http://www.nmsc.gov.au/media/pages_medi ... 0Boats.pdf
It seems that the buoyancy calcs/tests and maximum HP are the two that will be required as an owner builder for this type of vessel. If Glen-L has them, then a copy of them with a formal declaration is what I would need. Does Glen-L calculate such things or possess the necessary software for them?
Thanks.
Glenn.
BruceDow
Re: Gentry flotation and HP calculations - Any available?
Post by BruceDow »
To my knowledge, Glen-L does not have or supply that information.
Send a PM to Mr. Hot Rod... He wrote a very nifty spreadsheet took that helps with the calcs. It is lined up the the harmonized Canada/US regs (except for that little "metric" thing that we use). If Aus is similar, his tool may give you a great starting point. (I had a quick scan of your link, and they look similar)
You could use such a spreadsheet as "documentation" of your flotation calculations. (It looks very "official")
B.
Bruce.
Dow's Monaco Project
Trackhappy
Its amazing really, these Guys actually expect you to sink your boat to prove this.... :shock:
Trackhappy
Bruce Dow wrote:To my knowledge, Glen-L does not have or supply that information.
B.
Thanks Bruce. I have left a PM, we are Metric here. Makes calcs easier.
Mr Hot Rod
Post by Mr Hot Rod »
Glenn :
I received your PM and decided to post to the Forum since the topic keeps coming up ...
We've developed an Excel spreadsheet for calculating flotation foam requirements for the Glen-L Hot Rod. I gave Bruce Dow a copy of the spreadsheet which he deftly modified to suit his Monaco.
Disclaimer : The spreadsheet can be a little tweaky -- use at your own risk ! Regulations are constantly evolving, so modifications may be required to suit current standards.
Other links :
Here's a link which may provide some inspiration on how to install flotation foam billets. We installed most of the foam up high under the deck before laying the deck. Not much help when you're trying to retrofit to a finished boat, but useful if you're still in the build phase !
Please let me know if you have any problems loading the spreadsheet. If you have any questions along the way, post them to the Forum so we can expand our knowledge base.
Hope this helps !
____________________
Paul Kane
Kane Custom Boats Ltd.
Chelsea, PQ
Nova SS
Post by Nova SS »
I didnt see an answer for the HP part of the question. With an inboard powered boat there normally is not a max HP limitation like there is for outboard powered boats. The formula's I've seen deal totally with outboards. If you check out the inboard plans on the Glen-l site HP is not mentioned normally weight or cubic in of the motor is mentioned but not HP.
For my inboard the HP limit was my wallet :!: :wink:
Trackhappy
Nova SS wrote:I didnt see an answer for the HP part of the question. With an inboard powered boat there normally is not a max HP limitation like there is for outboard powered boats. The formula's I've seen deal totally with outboards. If you check out the inboard plans on the Glen-l site HP is not mentioned normally weight or cubic in of the motor is mentioned but not HP.
There seems to be another option for the maximum HP, being a maximum speed determined by the builder from testing turning standard corners at speed and measuring the maximum angle and freeboard. You have to have a speedo and have to have a plate visible to the driver stating the maximum safe speed. At least that is do-able. I don't like this having to have plates all over the place though, spoils the look of a nice Mahogany runabout.
Trackhappy
Mr. Hot Rod,
Thanks for all that, I guess I missed it when I searched the site. I will work through all this information and see what comes out. As you say, it is much easier to fit flotation at the building stage, which is why I asked now. Hopefully it will jog others memories at the right time as well.
billy c
Post by billy c »
Are you sure these standards apply to you?
it looks like they are addressing manufactured boats for sale and not homebuilt. We have similar standards for manufactured boats in the US also but they do not apply to homebuilt craft.
-Billy
Trackhappy
billy c wrote:Are you sure these standards apply to you?
-Billy
Yep, they specifically mention homebuilt if you are the builder. "Second Hand" is exempt, but then they state that it is not second hand if you are the builder and only user of the boat. Upon first sale to the public it must have a plate fitted. I am starting to wonder about Insurance on her now as well, probably based upon this same requirement. Have to check on that.
Trackhappy
Out of interest, I placed all the info I could find on Gentry into the spreadsheet and came up with a figure of 0.6 cubic metres of foam required to make her float. That is quite a bit to fit into a runabout, but I guess fill the areas between the deck beams, above the fuel tank and beneath the seats, will see as I go along where else I can squeeze some in.
Ron Filsell
Post by Ron Filsell »
Trackhappy :Go ahead and build the boat. The information on an ABP can only be approved by either, The Builder. The Importer. or a Competent Person. A competent Person is idefined as a person who has acquired through, Qualification, Experience,or Training or a combination of these, the skills enabling that person to competently determine and approve the information on the plate.
If it sinks when launched, I guess you may not be competent, if not I think you are. :D :lol:
NSW Waterways dont want to see the plate, they just want you to tick the box that says you do. But I didnt say that. :wink:
This was edited from a reply I posted early this year and may help you. With regards flotation there are 3 levels the lower (now discontinued is INADEQUATE) The next is ADEQUATE and the last is POSITIVE. only POSITIVE needs support the boat fittings and crew.
ADEQUATE only means the boat will float at some attitude and support people in the water. From this description its easy to establish why INADEQUATE is now discontinued.
Regards, Ron.
BruceDow
Post by BruceDow »
Trackhappy wrote:Out of interest, I placed all the info I could find on Gentry into the spreadsheet and came up with a figure of 0.6 cubic metres of foam required to make her float.
Hmmmm.... you might want to double-check.... (or I should!!!)... I built an 18' (5.5m) Monaco with a 283 v8. Using that spreadsheet and my input, I needed almost exactly half of what you came up with (296 Liters or approx. 11 cu. ft.). I can't see our boats being that different.
If you would like to PM me with your eMail, I'd be happy to send you my file for comparison.
Bruce.
Trackhappy
Thanks Bruce, will do. I must admit I guessed on weights of some things, such as the V8. I will be using the 350 Chev with Velvet drive and possibly fresh water cooled so that adds quite a bit. Anyhow, I will re-visit and see what comes.
