SC V6 or MPI V8?
- Mr Hot Rod
- Contact:
Hey, Duane ! We installed the coolers before the motor e.g. coolant flow is from the cam-driven pump to the coolers, then into the exhaust manifolds where the water is preheated before being fed into the engine water inlets. We used a 12" cooler for the engine oil (about 14 quarts) and a 9" cooler for the Velvet Drive. To maximize cooling, cool water must flow opposite the oil cooler oil flow. We've also lowered the transmission cooler so that it's located below the trans oil fill plug. This ensures that the trans is at the proper fill level and adds more oil capacity to the system.
__________________
Paul Kane Chelsea, PQ
__________________
Have you really looked at the plans? The depth of the hull is only 24" your motor will be substantially higher then this when measured from the bottom of the oil pan to carb. Plus you wont be able to rest the oil pan on the hull of boat so the motor itselt will be raised in the hull slightly. This will only add to the overall height of the motor. For your box to cover the motor it wil have to be well above the shears of the boat. I'm not sure how pleasing to the eye this setup would be. BUT of course beauty is in the eye of the beholderDenon Osterman wrote:probably, if it'll fit...might need a scoop over the carb, with a coarse filter to keep the bugs out![]()
yeah, thats why the whole "fitting" thing comes into play. i figure i can get a good 3+ inches with a coaming at the back, and then have the hatch rise a bit more in the center, to cover everything other then carb/air filter...which will either stick out or be scooped. but, we'll get the engine in first to see how realistic any of this is when we get there!
Denon
Denon
Here's a pic of a v-drive with covered engine....never cared much for this look myself....thought they were awkward and ugly
http://tampa.craigslist.org/pnl/boa/997495978.html
- Caber-Feidh
Just like freeboard-challenged jets... Not my style at all. But it does keep your motor from scaring children into crying at the beach. But what fun would that be??!?!?!?! Naw, I don't like that look either, too much like just another glastron in the showroom.upspirate wrote:Here's a pic of a v-drive with covered engine....never cared much for this look myself....thought they were awkward and ugly
Yes that is the exact 4-port housing. Good clean install too. If you use a blower they need an offset housing. Dwyer blower used to have them, I am sure they still do.
One of my father's friends was a well known motor builder from the golden days of road racing, He got me interested, then I built hillclimb motors for years (1981-1999). It was a hobby-business that got too big, along with building a few "kit-cars", it started affecting my real job, well, when I had a real job. Ah, but I still enjoy a good GTO car, but they are hard on my driving record. I decided it was time to find some other way to enjoy hot-rodding when the traffic court judge asked me when I was going to be old enough to quit acting like a teenager. I am not sure if it was the display of HP, or the exhibition driving, or maybe the unreasonable acceleration... no, wait, it was the obstructed vision ticket (blower in the way? heck, I could see around it fine!). In any case, boats were easier on my insurance! And I have never looked back. I started with V-drives but moved to a lake that often has less than 2 feet of water in the channel to the "big lake". Then I discovered that the ideal jet motor was the same as a perfect hillclimb motor, it was a match made perfectly for me!Denon Osterman wrote:Caber, forgive me if this is a personal question, but does this vast wealth of knowledge of yours spring from profession, or merely personal interest? Either way, great stuff...thanks again! Will be going over all of this with my dad on the weekend, so when we've made our decision I'll be sure to let you know so you can help out with specific parts![]()
THANKS!!!
Denon
Being the hard headed sort, I usually have to learn anything the hard way, usually by reading what to do, then doing it wrong the first few times. Hard on the parts budget sometimes, but isn't any learning experience.
When you pick parts, you will find a wealth of info here. It's nice to get the input of other v-8 builders in the forum. There are a few decent motor-heads from what I have read. Just be sure to ignore Bill... his idea of going fast involves burning kerosene, and hanging a bedsheet from a tall pole, then praying for wind!
- Fifty Plus
Now that I have stoped LOL, I feel that I should be added to the ignored list. I burn kerosene and can hang 1/2 a bedsheet on a much shorter pole. I however do not pray for wind, I just take what comes. Oh, by the way, my idea of going fast is 7 mph.
If not now......When?
http://s270.photobucket.com/albums/jj94/gashog7/boat/
http://www.epoxyworks.com/26/index.html Number26
- Bill Edmundson
- Contact:
Now wait a minute! I resemble that remark!Just be sure to ignore Bill... his idea of going fast involves burning kerosene, and hanging a bedsheet from a tall pole, then praying for wind!
- Dave Grason
Denon, I have a question for you?
Is this a serious project you're in the process of building right now, or are you just drumming up questions to see your posts in print?
