It is currently Fri Sep 10, 2010 12:57 pm
 Post subject: rpm range.
PostPosted: Fri Jul 30, 2010 8:00 am
For you inboard guys (and maybe to a lesser extent outboard guys just for a compairison) What do you think the rpm range is that you use your boat in the most. For example 1500rpm and up, 2000rpm and up, etc, etc. I'm not too concerned about the max rpm but I'm wondering about the lower end of the range. The reason I'm wondering is I'm looking at cams and they are advertised more often then not with an rpm range they work well for. Such as 1500-5000, 2000-5800, 2500-6200, etc, etc. When you guys are towing someone on a tube what rpm are you running at? I know different hulls, motors, props, trannies, etc will impact this number a lot but I'm still interested in knowing what you're running rpm wise for this kind of stuff. For a car this would be an easy exercise for me but I'm having problems doing this for the boat.
Thanks
 Post subject: Re: rpm range.
PostPosted: Fri Jul 30, 2010 8:51 am
1500-3500
PostPosted: Fri Jul 30, 2010 9:02 am
I run the most between 25 and 30 mph. Which on my diesel is 2500 to 3000 rpm.
Mini -Tug & KH Tahoe 19 - There can be no miracle recoveries without first screwing up.
PostPosted: Fri Jul 30, 2010 9:34 am
Sweet spot on most 2 stroke outboards is about 3300-3800....I run around 3400
Can't remember where my V-drive was used mostly....maybe 2000-2500
It needed more % overdrive though....would go way beyond the 8000 top on the mechanical tach (I didn't run past about 6000 though except for a couple of passes)
If it doesn't fit right,it isn't
When you dance, your purpose is not to get to a certain place on the floor. It's to enjoy each step along the way. ~ Wayne Dyer ~
you will be more disappointed by the things you didn't do than by the ones you did do
PostPosted: Fri Jul 30, 2010 2:32 pm
I run 2800-3300
PostPosted: Fri Jul 30, 2010 7:32 pm
Thanks guys, this has been helpful :)
PostPosted: Sat Jul 31, 2010 5:33 am
From what I have read , it is torque that moves a boat. Of course torque and RPM have a close relationship so if you look at graphs that show this relationship then the max torque for a given RPM would be most efficient.
PostPosted: Sat Jul 31, 2010 3:51 pm
Every outboard has a "sweet spot" which is often called it's "cruise speed". It's easy to find on older carb models that have mechanical spark advance because it's the point where the motor reaches maximum advance (trigger linkage is fully advanced and won't move anymore even if you increase the throttle) but you still have throttle left - so normally in the 3300-4300'ish rpm range on a 2 stroke outboard.
That "spot" will always give you your "best" mpg (only burn about 1/2 as much gas as full throttle)- regardless of what "speed" that translates into. So might be well suited if you are "cruising", but may too fast/slow to pull a tube or skier etc..
Graham
PostPosted: Sun Aug 01, 2010 9:54 am
5600-ish :D :D :D :D :D :D
Cam selection is allot more than RPM range. There is no other single aspect of engine building that will have as dramatic of impact on performance... CR being a close second. You need to look at more than RPM range assigned by the grinder.
* Wet exhaust will develop a backpressure higher than the cam was designed for (unless it's marine specific) High overlap, and high lift can be counterproductive depending on exhaust system.
* There is no way to accommodate a cam with no low end in most screw-driving marine designs.
* The cam has to have a flat, or slightly-inclined torque curve, and no big valley between torque, and peak HP, or it will never pull into the top end. The lightswitch powerband of a tall cam is not going to cut it for a marine motor.
There is reaaaaalllyyyyy no way to make an intelligent decision without knowing which hull, what drive, which engine, CR, head specs, intake, carburetor, and just what you want to get out of it. Forgoing that data, usually a cam specified as "RV" or "towing" is ideal for the typical cruiser-type boat. It's way too easy to get greedy, and fall victim to the RPM, and HP ratings, then pick more lumpstick than you need.
"Vision without execution is hallucination."
— Thomas A. Edison
PostPosted: Sun Aug 01, 2010 10:49 am
Does anybody have info on wet exhaust manifolds that would flow good enough to accept the better cams?
Other than the over-the-transom headers, I havent noticed manifolds that could flow well enough. I still dont see how a log-style manifold can flow very well.
PostPosted: Sun Aug 01, 2010 7:32 pm
Here's some info from Lightning Performance Marine :
    (boatheaders.com)
____________________
Paul Kane Chelsea, PQ
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
