Can the 11' Utility boat be shortened in the beam?
Posted: Sun Sep 06, 2020 3:27 pm
Hello. I have been lurking for quite awhile and I think I'm ready to buy some plans. I have been wanting to build a power cruiser when I retire, but at this point, I really want a small start now since I'm not going anywhere anytime soon.
Problem is, I don't have a garage and since I live on a military base, I can't really build outside. So I'm looking at a 11' Utility so I can build in the basement (I plan to bring it outside to sand or other times I need a ventilated area) but found that the stairs leading into the basement are a bit too steep.
I built a mockup of what I thought the 11 foot Utility boat might look like (based on Glen-Ls specifications and pictures). When testing the stairway exit, it was a no-go. I really like the shape and look of the 11 foot utility boat. Near flat bottom (technically the utility is a vee bottom). I like that its an 11 footer, although 12 would have been nice too. I think the most distinctive feature that I like of a boat is that the rear (stern) tapers in the width from the most widest part of the boat. I don't think I need a 5 foot wide boat, so I'm wondering if the beam can be shortened to 4 or 4 and a half feet. I'm not sure if that what would make the difference here, but I think if it was just slightly narrower, it might get out (I'm planning to narrow the beam of my mockup and see if 4 or 4.5 might make a difference).
See attached pictures. I started with the bow going out (not shown in picture), and then turned it around to see if that would work (picture shown). The dimensions were 132 inches front to back and 60 inches at its widest part.
Other designs I like are the 11 foot power row skiff (half a foot narrower for the NB version). The row-me looks nice, but is nearly 5 foot wide. The fife might work (12 foot long, 3 foot 8 inches wide). The bulls eye is my second favorite, but wasn't sure if the keels were necessary if I wasn't putting a sail on it.
Questions I have
Can I shorten the beam of the 11' Utility boat?
If I go with the Bulls-eye, can I remove the keels (as in, not build them).
Am I missing any other good options?
Thanks in advance.
Questions I have
Thanks in advance.
