best glue for vertical bonding
Canoes, Kayaks, Pedal power
BruceB
Post by BruceB »
I am ready to glue the plywood sides to the chines and sheers. I have been using epoxy w/hardener with a peanut butter consistency. But, it still sags and could get pretty messes. I have seen epoxy and hardener in a caulk tube that says no sag, but it is pretty expensive. Lastly, there is 3m 5200. Any suggestions on what has worked for all of you?
Re: best glue for vertical bonding
What are you using to thicken? If you add enough thickener it won't sag.
BruceB wrote:
Sat Jun 22, 2019 11:57 am
Gloves! :lol:
I like the caulk tubes. Yes, they aren't cheap. Get an extra tip or two. Tubes come with a reusable cap. Throw away the tip and get another. It's fast you can put it exactly where you want to work. Spread the bead with stir stick.
BruceB
Post by BruceB »
Milled glass fiber
Sarnian
Post by Sarnian »
its expensive but system 3 gel magic is absolutely fantastic - it doesn't sag and is incredibly easy to mix
marlinmorris
Post by marlinmorris »
I bought powerful glue for wood form Ritecoupons. It is quite expensive but result is best. P.S: don't forget to wear gloves while using glue, it may damage your skin.
Post by chugalug »
If you use Gorilla and get it on your hands,you'll know why they call it Gorilla.It changes you into one.That black stuff on your hands has to wear off :lol:
steveh41
Post by steveh41 »
System 3 Gel Magic is a great product for vertical or overhead bonding. The cartridge with mixing tip is quite a bit more expensive than buying in plastic containers...
parsj1957
Post by parsj1957 »
I've had success minimizing the mess by taping the seams off like you would for painting - tape and a piece of brown paper - then the vast majority of any dripping/oozing epoxy runs out onto the tape and paper. Once it gels (stops dripping) I remove the tape/paper to avoid it being 'epoxied' to the surface -- not 100% perfect but sure minimizes the cleanup effort -- so for me its been a big net positive time tradeoff.
J.
savingrite
Post by savingrite »
The construction adhesives is an alternative solution for they can successfully bond on many substrates. We’re recommending the usage of LIQUID NAILS® in Ultra Qwik Grip {LN-990} to adhering to porous surface & LIQUID NAILS® FUZE*IT® In the all surface construction Adhesive (LN-2000) to the most surfaces for getting vertical material intact.
Return to “Human Power”
