Building a RowMe in New Jersey
Canoes, Kayaks, Pedal power
jpvernon
Re: Building a RowMe in New Jersey
Post by jpvernon »
Thanks Bill! Yes, the foam sheets didn't seem all that expensive,...so I think I will go that route.
Good idea on drain plug,...need to find that as well.
- John
John
The foam is available at most upholstery supply houses. Glen-L has the plugs and sleeves. Can find plug in most sporting good departments. Boaters loose them all the time. No more foam than you'll need the sheets aren't that bad$
jpvernon
Post by jpvernon »
Thanks for the info Bill! Will look into that.
Last night, it was 27 degrees here in Northern New Jersey,...so the going is pretty slow now.
Then there's that four-letter thing called "work".
- John
jpvernon
Post by jpvernon »
Have all the seat uprights completed as well as the seat supports attached to the uprights.
Finished the transom,...and decided to lower for a motor at some point. 5 HP is the most HP to use.
I have an electric motor, but may look into a used 5 HP at some point.
I also have the motor mounts finished and attached as well.
Need to attach the transom, then fillet the inside seams,..after that, it's fiber glass the inside seams.
Brought the foam sheet needed for flotation.
I'm not looking forward to ripping the 14 ft mahogany board for the sheers,...mainly because I don't have a table saw.
I may have to purchase one or build a table and use my circular saw.
- John
Hi Jp,
Sounds like you're making good progress.
While I have a table saw, my shop was too small to get a 14" board through it for my sheers and chines. I hauled them over to a friends shop who was glad to do me a favor. I would check around with your neighbors or work colleagues to see if someone can help you out. Or maybe a local woodworking shop (e.g., Woodcraft or Rockler) or lumber yard.
Later,
jpvernon
Post by jpvernon »
Finished the transom finally and just wired it in. The boat is officially and totally wired. Now onto fillets.
- John
jpvernon
Post by jpvernon »
Finally able to start working on the rowboat again.
Over the weekend, I added the fillets and the next day removed all the stitches.
Hey, what do you know, it didn't fall apart.
First batch of epoxy mix for fillets a lesson on "what not to do".
Subsequent mixes were fine.
jpvernon
Post by jpvernon »
Wow,..my last post was June,..time is not my friend.
I managed to epoxy fill the gaps on the inside seams.
I had had some problems with the bow where my boards just were not meeting enough.
Luckily,...with a little tape on the outside covering the small gap, I was able to epoxy fill the gap.
I've started sanding the inner seams to smooth the epoxy fill enough for the fiberglass tape.
Now I see,...this will take some amount of time,...longer than I had thought it would.
I had a thought to sand the inner seat areas, clean, then epoxy coat, then fiberglass those seams.
Then I can install the flotation foam and install the seat.
It'd sure give me a sense of progress,....but part of me wants to sand the whole inside first.
I have pictures,..but need to find the time to post so you can see the progress.
Hopefully my next update doesn't take another 2 months.
jpvernon
Post by jpvernon »
Been over a year since my last post.
I kind of got stuck on starting the inside fiberglass.
After getting over being intimidated, I started with one small area.
Not as bad as I feared,....and now I just finished fiberglassing all inside seams.
Also have the front and middle seats filled with flotation foam and then sealed.
Next up, need to rip the sheers, install the inside sheers, install the breast hook and the transom knee.
Then flip and fiberglass the hull. Then it's onto sanding and painting.
Oh and somewhere in there, install the skeg.
Next update,...ah, who knows.
jpvernon
Post by jpvernon »
So it's 8 months later.
Still chugging along but I did make a lot of progress this past month!
Here's what I've done:
Ripped the first sheer and burned out my table saw motor in the process (don't ask).
I created a jig for my circular saw which finished the ripping job.
Installed the inside sheers, the oarlock braces, the breast hook and now working on the transom knees.
Will need to install blocks on the transom so I can screw the handles on the back of the transom when the times comes.
Also need to install a block in the breast hook on the bow for the eye hook as a support.
Once that's done then flip and fiberglass the hull. Then it's onto sanding, install outer sheer, and then painting.
Then install the skeg, flip it over again and finish the inside.
I said it before, but I have taken pictures along the way,...so I promise to post those at some point.
-John
Mark-NJ
Post by Mark-NJ »
OK...someone has to say it....
jpvernon
Post by jpvernon »
Wow! Way to troll and express your opinion for everyone Mark. :evil:
"No soup for you"
- John
Mark-NJ
Post by Mark-NJ »
Just hoping to see some pictures....that's all.
Never mind.
jpvernon
Post by jpvernon »
For me, a quick update was cathartic. Makes me feel like I'm pushing myself to get this done in spite of everything going on.
If nothing else, this thread is my journal so I can look back and see how long, and know why things hit speed bumps.
I saw someone built this boat in 2 months. So far, I'm up to almost 3 years.
I will get it done.
jpvernon
Post by jpvernon »
I just uploaded a ton of pictures and created a Gallery.
Emailed the admins to let them know and now waiting for them to activate the Gallery.
Once it is viewable, I'll post the link here.
I'll still be posting progress here, but all pictures will be updated on the Gallery as time permits.
- John
Return to “Human Power”
