A little progress this week. Most of my time was spent making sure I understand the instructions fully, to prevent any mistakes. I did the scarf joint that I needed to do. It was to attach about 10" to the end of one side. It isn't pretty but should work fine after I glass it.
The seats needed a 5/8" groove on the underside for the seat supports to fit. I pulled out the router and finished that task.
I then went over the parts and started to mock up for fit and see that things made sense. This pic shows the floor, which will sit on top of the boat bottom, along with the transom, brace, and seats in place.
I missed that the rear seat was supposed to have a 20 degree angle on the side edges, facing down. So I set up the table saw and made the first cut. Right after cutting, it became apparent that the angle was facing up, not down.
First big mistake! Immediately I had visions of having to travel to Annapolis for more wood, would they have any scrap big enough or will I need to buy a whole 4x4 sheet, etc... but then sanity took over and I realized that I could glue a piece on the end and re-cut.
So I did and it turned out just fine.
This week, I will be installing blocking and fasteners in the mock up phase. These pics show the layout of all the pieces.
Almost looking like a boat!
