BILL
Fitting involves more than matching the contour of the previous piece. Move a veneer forward of the last piece, bend it around the contour, shift on its axis until there is no buckling, then fit to previous plank. If you can't eliminate buckling, make the strip narrower. They need not be all the same width.I splined each plank to a perfect fit and still I get buckles in the sides.
